Loader Bobcat 773 has codes 05-14 and 04-14 and turns off
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #1
dashin3
bobcat 773
Hello I have a bobcat that has about 1600 hours. Once I pull the lever down and turn on the lights. The bobcats turns off shortly. I have tried different things and cant figure it out. The codes that come up are 05-14 and 04-14 and then turns off. If you have heard or had this experience please help.
Thanks
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #2
I think you might get a better answer to your question if you posted it the "Bobcat Construction Equipment" section of the forum that deals with skid steer units.
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #3
05-14 - Hydraulic charge pressure extremly low :
1. Low hydraulic level
2.Low hydraulic charge pressure
3.Hydraulic charge pressure sensor
04-14- Engine oil pressure extremly low :
Because there is also 2 mistakes maybe the problems will be connected with electrical wire or controler or socket. Check everyone connectors they are locked good and maybe corrosin or pushed back pins .
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #4
Thanks
Check the drive belt tension. Make sure the pointer is facing rear.:thumbsup:
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
