Loader Bobcat 773 has codes 05-14 and 04-14 and turns off
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #1
dashin3
bobcat 773
Hello I have a bobcat that has about 1600 hours. Once I pull the lever down and turn on the lights. The bobcats turns off shortly. I have tried different things and cant figure it out. The codes that come up are 05-14 and 04-14 and then turns off. If you have heard or had this experience please help.
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #2
I think you might get a better answer to your question if you posted it the "Bobcat Construction Equipment" section of the forum that deals with skid steer units.
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #3
05-14 - Hydraulic charge pressure extremly low :
1. Low hydraulic level
2.Low hydraulic charge pressure
3.Hydraulic charge pressure sensor
04-14- Engine oil pressure extremly low :
Because there is also 2 mistakes maybe the problems will be connected with electrical wire or controler or socket. Check everyone connectors they are locked good and maybe corrosin or pushed back pins .
   / Bobcat 773 has codes 05-14 and 04-14 and turns off #4
Check the drive belt tension. Make sure the pointer is facing rear.:thumbsup:
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
INGERSOLL RAND G25 GENERATOR (A50854)
INGERSOLL RAND G25...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
