Bobcat 763 Loader Arm Question
/ Bobcat 763 Loader Arm Question #11
I think that's the answer: no, I didn't disconnect both sides of each cylinder; there was only one line on each cylinder that was visible to me but I didn't know enough 4lOvernight, the loader cylinders retracted enough to provide clearance to get the door open.
Other hose is near bottom of cylinder towards you can be reached from inside back on some. I only know about some because I've only had some apart.
I had to use that window escape once when I was mowing in the woods, got stuck at an angle/position where the loader arm blocked the door. On the way out, was a bit tricky getting around the hot exhaust stack. And a PIA to get the window back in right. Yes, taking the door off when not needed is a good practice but I use the bushcutter quite a bit so usually leave it on all the time.
/ Bobcat 763 Loader Arm Question #13
try jacking the front of the machine up then crack the lines
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
