BobCat 753
/ BobCat 753 #1
REA
Raymond, Maine
(3) Gravely Tractors L8
When I work my BobCat hard it will lose the hydrulic oil. What could be done to stop this condition? Thank you.
REA:)
/ BobCat 753 #2
REA:)
What happens to the hydraulic fluid? Is it leaking out on the ground or seems to be disappearing, and you don't know whare it is going?
/ BobCat 753
It leaks out onto the ground. I live in an association so have to try my best to keep it cleaned up. Thank you for your reply.
REA
/ BobCat 753 #4
Trace the leak back to where it is coming from, the fix it. May be a loose fitting, worn hose, or leaky O-ring or seal somewhere. Just keep looking until you find it.
/ BobCat 753
OK Dennis,
I will do that! Only problem is on a BobCat Skid Steer the covers are heavy, then when you get them off it is very hard to reach in and fix anything. Looks like oil coming from around the hydrualic motors? Thank you.
REA
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2017 International HX620 Quint Dump (A62613)
2017 International...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
