Bobcat 753 will not move
/ Bobcat 753 will not move #1
cpp
I have a Bobcat 753 that is stuck down below my house. I ran it for about an hour today moving some dirt around. A warning alarm came on citing hydrostatic oil was low so I stopped and check it. It did not register on the stick so I added 2 gallons and it started to register and appeared to work fine. I drove it about 100 feet and the alarm came on again. Shut her down and noticed a huge puddle of oil started to form under the machine. I see what appears to be a plate on the side of the machine that looks like an access panel. Do I need to remove the wheels to get this out. Appreciate any advice or troubleshooting info from someone who has a little experience with these machines. Thanks in advance.
/ Bobcat 753 will not move #2
I would start by lifting the cab and see if you can tell where the leak is coming from.
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
Caterpillar GC40K Forklift (A61166)
Caterpillar GC40K...
Informational Lot - Financing (A63688)
Informational Lot...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
2015 John Deere 1775NT Planter (A63109)
2015 John Deere...
