Bobcat 751 G series lift and tilt wont work
   / Bobcat 751 G series lift and tilt wont work #1
iceman81105
venus fl
kubota B7400
I have a Bobcat 751 G series and cant get the bucket to move up or down.
Checked the fuses,relays all fine. I push the button to unlock the tilt and no light.
Only the Traction light comes on and it will move back and forth. The seat/bar light will
Flash two times then goes out then flashes two times then goes out?
   / Bobcat 751 G series lift and tilt wont work #2
2 flashes is seat/bar short to Battery voltage. Bad sensor I'm guessing. DO NOT JUMP SENSOR! You can fry a very expensive controller. That sensor is a hall effects sensor an operates on 5v. Your dealer has a test device that will test it safely.
Niles Pond Engine Lathe (A59213)
Niles Pond Engine...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
36in Digging Tooth Bucket Excavator Attachment (A56857)
36in Digging Tooth...
2008 Ford F-150STX (A57148)
2008 Ford F-150STX...
2013 International Dura Star (A57148)
2013 International...
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
