Bobcat 751 G series lift and tilt wont work
   / Bobcat 751 G series lift and tilt wont work #1
iceman81105
venus fl
kubota B7400
I have a Bobcat 751 G series and cant get the bucket to move up or down.
Checked the fuses,relays all fine. I push the button to unlock the tilt and no light.
Only the Traction light comes on and it will move back and forth. The seat/bar light will
Flash two times then goes out then flashes two times then goes out?
   / Bobcat 751 G series lift and tilt wont work #2
2 flashes is seat/bar short to Battery voltage. Bad sensor I'm guessing. DO NOT JUMP SENSOR! You can fry a very expensive controller. That sensor is a hall effects sensor an operates on 5v. Your dealer has a test device that will test it safely.
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
(2) UNUSED 3500# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 3500#...
7046 (A50322)
7046 (A50322)
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
