Bobcat 743 Hydraulic Control Valve
   / Bobcat 743 Hydraulic Control Valve #1
ymdeng
Ruskin, FL
Bobcat 743
The 3rd Spool from top leaks.
   / Bobcat 743 Hydraulic Control Valve #2
Is it a mono block or a stacked valve?
Some valves have o-rings for seals and others are a precision fit.
If the precision spool is leaking, it could be worn and probably is not replaceable.
If the spools have o-rings, there are kits to replace them.
If it is a stacked valve, a single stack can be replaced.
If it is a small leak, you may have to live with it.
I don't know the standard for a so called leaking valve, but some manufactures use a leakage of over 10 drops per minute, and would warrant replacing.
It's mono block, see attached. Leaks from the 3rd from the top (see from the rear (engine side)). I am considering replace the whole control valve.
   / Bobcat 743 Hydraulic Control Valve #4
Is this valve a remote valve, and does it have any special features on it?
This valve has no use in current machine. It has no linkage in the front. The other 3 valves have linkages to lift, tilt, and front auxiliary hydraulics. I think this one is a space for pontential rear Auxiliary hydraulics.
   / Bobcat 743 Hydraulic Control Valve #6
Is the that valve the last valve in series before the fluid goes to tank?
If it is, and you don't need it, you could remove the valve and replace it with a coupler.
If that valve has PB, then you would couple the IN hose to the PB, and plug the OUT hose.
2012 Ford F-250 4x4 Pickup Truck (A50323)
2012 Ford F-250...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
Toro Mower (A50324)
Toro Mower (A50324)
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2024 John Deere 6110M (A50120)
2024 John Deere...
