bobcat 743 hyd lift pump
   / bobcat 743 hyd lift pump #1
DMorphew
743 bobcat
I have 743 bobcat, when raising the lift arms the pump squeals unless I increase the rpms, the more weight the more rpms required to lift. I had the valve body rebuilt, prior it wouldn't lift anything. Does it need a new hyd lift pump?
   / bobcat 743 hyd lift pump #2
is it the pump or the relief valve? have you tested the hydraulic pressure
Good question, I'm not sure at this point. I tired to find pictures on location of relief valve, couldn't find any. Would you by chance have one?
   / bobcat 743 hyd lift pump #4
if I recall the relief valve is on the block for the arms tilt and auxiliary, open the machine and on the right side about level with the rear of motor there should be a valve block, if you take a pressure gauge, add a bobcat connector and plug it into the auxiliary port, rev motor and operate the auxiliary lever, the pressure it reaches will be the relief pressure
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
