bobcat 743 hyd lift pump
   / bobcat 743 hyd lift pump #1
DMorphew
743 bobcat
I have 743 bobcat, when raising the lift arms the pump squeals unless I increase the rpms, the more weight the more rpms required to lift. I had the valve body rebuilt, prior it wouldn't lift anything. Does it need a new hyd lift pump?
   / bobcat 743 hyd lift pump #2
is it the pump or the relief valve? have you tested the hydraulic pressure
Good question, I'm not sure at this point. I tired to find pictures on location of relief valve, couldn't find any. Would you by chance have one?
   / bobcat 743 hyd lift pump #4
if I recall the relief valve is on the block for the arms tilt and auxiliary, open the machine and on the right side about level with the rear of motor there should be a valve block, if you take a pressure gauge, add a bobcat connector and plug it into the auxiliary port, rev motor and operate the auxiliary lever, the pressure it reaches will be the relief pressure
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
