Bobcat 610 Drive Sheave Issues
   / Bobcat 610 Drive Sheave Issues #1
jeffscoggins
Brainerd, MN
Melroe 610
I'm new to the Bobcat 610 and the other day my drive sheave flew off the drive shaft (Honda engine). I installed a new belt and hydraulic hose, which broke, and when I started it the drive sheave immediately came loose again. I can't tighten the set screws any harder, I don't think. Do I have the balance off? I'm pretty clueless about how it is supposed to work so any help will be appreciated!
Jeff
   / Bobcat 610 Drive Sheave Issues #2
A Melroe 610 Bobcat with a Honda engine??? I know of a Briggs Vanguard engine that fits in a 610 but was unaware of a Honda. Are you using the "factory" drive sheave or is this something supplied by Honda?
   / Bobcat 610 Drive Sheave Issues #3
I have had two Bobcat 610's over the years. They both had the Wisconsin V4 engine made for that clutch drive. I know that there is a Briggs re-power that has a special piece machined for the clutch. The shaft should be tapered and fit tight enough to need a puller to get it off the crank.
LG TRUE BALANCE WASHER & DRYER (A51248)
LG TRUE BALANCE...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2015 TAKEUCHI TB290 EXCAVATOR (A51246)
2015 TAKEUCHI...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
2013 Ford Fusion Sedan (A51694)
2013 Ford Fusion...
