Bobcat 445 PTO Will Not Engage
   / Bobcat 445 PTO Will Not Engage #1
fshnguy
Corvallis, OR
Ford 2600
I was mowing today and for no apparent reason the PTO stopped turning the mower deck. I can turn the driveshaft by hand and the blades turn inside the deck unit but the driveshaft from the tractor tranny will no engage spin. It's like it isn't receiving the order from the PTO switch to engage. The shaft turns by hand a slight bit forward and backward but stops hard each direction. When I pull the electric PTO switch, the PTO light on the dash comes on but nothing engages.
I have checked the fuses in the fuse panel under the dashboard. Have not checked any of the relays. Not sure how. An amp / voltage tester perhaps?
Any suggestions would be very appreciated.
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 Kubota SVL97-2 (A50120)
2021 Kubota...
EZ-GO RXV Electric Golf Cart (A50121)
EZ-GO RXV Electric...
