Bobcat 445 PTO Will Not Engage
   / Bobcat 445 PTO Will Not Engage #1
fshnguy
Corvallis, OR
Ford 2600
I was mowing today and for no apparent reason the PTO stopped turning the mower deck. I can turn the driveshaft by hand and the blades turn inside the deck unit but the driveshaft from the tractor tranny will no engage spin. It's like it isn't receiving the order from the PTO switch to engage. The shaft turns by hand a slight bit forward and backward but stops hard each direction. When I pull the electric PTO switch, the PTO light on the dash comes on but nothing engages.
I have checked the fuses in the fuse panel under the dashboard. Have not checked any of the relays. Not sure how. An amp / voltage tester perhaps?
Any suggestions would be very appreciated.
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2005 Nissan Titan (A50120)
2005 Nissan Titan...
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
