bobcat 440b blowing fuse
   / bobcat 440b blowing fuse #1
teamdirt
Hi,
i am new to this forum and need some help advise, my bobcat 440b skidsteer keeps blowing the fuse, i have checked for any shorts but can not find any, does anyone have a wiring schematic for this thanks paul
   / bobcat 440b blowing fuse #2
Hi, Yes I have a wiring schematic for the 440B. It's in the operators manual if you have one. I'm new as well and not particularily comp literate. I can scan it and send via e-mail if I have an address. To address the problem, the five spade ignition switch female plug probably has very dirty terminals. I experienced the same problem , but rather than clean them I replaced the switch and cut the plug off and put single spade females on . Problem gone... The switch is an INTEK and you can find them in most tractor supply parts catalog
   / bobcat 440b blowing fuse #3
:welcome:
Hopefully "teamdirt" found his problem within the last four months. :)
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2017 UTILITY VS2RA...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
UNUSED CFG QUICK ATTACH HYD HAMMER (A51248)
UNUSED CFG QUICK...
(INOP) CATERPILLAR CB-434 SMOOTH DBL DRUM ROLLER (A51247)
(INOP) CATERPILLAR...
