bobcat 440b blowing fuse
   / bobcat 440b blowing fuse #1
teamdirt
Hi,
i am new to this forum and need some help advise, my bobcat 440b skidsteer keeps blowing the fuse, i have checked for any shorts but can not find any, does anyone have a wiring schematic for this thanks paul
   / bobcat 440b blowing fuse #2
Hi, Yes I have a wiring schematic for the 440B. It's in the operators manual if you have one. I'm new as well and not particularily comp literate. I can scan it and send via e-mail if I have an address. To address the problem, the five spade ignition switch female plug probably has very dirty terminals. I experienced the same problem , but rather than clean them I replaced the switch and cut the plug off and put single spade females on . Problem gone... The switch is an INTEK and you can find them in most tractor supply parts catalog
   / bobcat 440b blowing fuse #3
:welcome:
Hopefully "teamdirt" found his problem within the last four months. :)
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
SHOP BUILT 96" X 25' TRI AXLE GOOSENECK TRAILER (A51247)
SHOP BUILT 96" X...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
