Bobcat 435 mini x problems, need help
   / Bobcat 435 mini x problems, need help #1
Crystal Waterscapes
bobcat 435 fast track
I have a bobcat 435 mini exc fast track. I was working on it when I heard a snap or crack noise and the tracks quite turning. All the other hydraulics are still working. When I try to move forward or backward I get absolutely no response. I dont see any hydraulic leaks. My machine is stuck on a job site, I need to finish and get it out of there ASAP. Any ideas on what the possible problem and fix may be.
Thank you for your help
Robert
   / Bobcat 435 mini x problems, need help #2
If it is a "Fast Track" model, it has a belt driven hydrostatic pump. Sounds like the belt may have broke. All other hydraulics would work fine, they are run from pump directly on end of the engine. Hydrostatic pump is under the right side hood just behind the radiator.
BOX OF SCHUMACHER1.5A BATTERY CHARGERS (A51248)
BOX OF...
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
23222 (A50323)
23222 (A50323)
John Deere 2020 Pro Gator (A50123)
John Deere 2020...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
2007 GMC C4500 Mechanics Truck (A52384)
2007 GMC C4500...
