Bobcat 331 Won't shut off
/ Bobcat 331 Won't shut off #1
Colton, OR
Bobcat 331
Hi guys. I went to shut my 331 off the other day and when I shut the key off and pulled it out the engine kept running. Is that a faulty ignition switch? Finally the engine shut off after 30 minutes of messing around with different stuff. The 20amp fuse to the start circuit blew which appears to be what shut it down. Even though pulling the fuse earlier had no effect. That again points to a faulty ignition switch right? What is the best way to shut down a diesel when the key won't do it? I tried choking the intake but couldn't get a good enough seal to make it stop running. Any help would be greatly appreciated.
Good point! This machine had been sitting for four years. It has a few sticky parts. I'll check it out. Thanks.
/ Bobcat 331 Won't shut off #4
If dash lights or guages turned off with key, then problem not likley in ignition switch. The fuel solenoid is power on, spring loaded off. It uses 2 circuits for on. 1st is high amp pull that is only on for about 3/4 second this goes through a timer & relay, if timer or relay stick power is there continuosly and will eventually short the solenoid internally. 2nd circuit is low amps to hold solenoid after the high amp pull it to ON.
One possiblity is: Relay stuck on sending constant high amp to solenoid thrugh the Pull circuit, this eventually shorted out the solenoid and the fuse allowing it to shut off. The pull circuit takes voltage directly from battery power, through fuse, through the relay, and back to solenoid.
/ Bobcat 331 Won't shut off #5
To answer the question about shutting one down. just put it in the highest gear you got and dump the clutch... not ideal but hey neither is the key not working.
Thanks Dennis. That sounds right. Now if only my multimeter was working properly! Well off to the autoparts store for a new one. I'll let you know what I find.
So it looks like an intermitant problem now. I did find a few chaffed wires going to the fuel solenoid. I taped them up and haven't had a problem since but I haven't been running it much either. I did check the fuel solenoid and timer for resistance and it seems to have checked out ok. Hopefully it was just those wires...I'll write back if I start having problems again.
/ Bobcat 331 Won't shut off #8
Alright! Good luck with it. :thumbsup:
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
TIRE REPAIR WORK BENCH (A68842)
TIRE REPAIR WORK...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
