Bobcat 325G excavator code 65-06 "work group / lockout solenoid short to ground".
   / Bobcat 325G excavator code 65-06 "work group / lockout solenoid short to ground". #1
shameless
john deere 3038e
The only solenoid I see in the repair manual is the system bypass solenoid. I unplugged it and the code did not change. If I have the right one I am thinking it must a wire shorted out. Does anyone know if this is the right solenoid and what ohm reading the coil should have? Thanks.
I found the information needed and will be checking it today. Thanks
   / Bobcat 325G excavator code 65-06 "work group / lockout solenoid short to ground". #3
If unplugging the system bypass solenoid didn't change the code, it might not be the issue. Double-check the solenoid you’re looking at to make sure it's the right one. The coil’s ohm reading usually ranges from 10-20 ohms, but you should verify with your manual. Also, inspect the wiring for any shorts or damage.By the way, I recommend that you choose the Bobcat 322 excavator instead of the Bobcat 325. If you wish, you can see the Bobcat 322 specs below.
2014 WESTERN STAR 4900 TRI AXLE (A45046)
2014 WESTERN STAR...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
2004 Ford F-650 Super Duty (A44501)
2004 Ford F-650...
2005 IMS 5012 LP VERSI DREDGE (A45046)
2005 IMS 5012 LP...
2006 VOLVO VNL (A45046)
2006 VOLVO VNL...
2019 INTERNATIONAL LT625 SLEEPER (A45046)
2019 INTERNATIONAL...
