Bobcat 322 will not start after it was tipped over
   / Bobcat 322 will not start after it was tipped over #1
kayesport
Brighton
Bobcat 322
Can anyone help me please
bobcat 322 fell down a hole and was on an extreme angle while trying to push myself out it ran out of fuel I presume and stopped
I have tried to bleed the system it turns over and pumped smoke out of the exhaust
Sometimes it fires that will not read up it just like runs at low RPM and then stops then will not start again
Any help would be greatly appreciated
   / Bobcat 322 will not start after it was tipped over #2
:welcome:
To TBN Kayesport from the USA. It sounds like it is flooding out. Does it have an automatic choke. If no choke then the the fuel regulator.
   / Bobcat 322 will not start after it was tipped over #3
Typical symptoms of a diesel running out of fuel. Keep cranking it, letting it fire a few times and stall, etc. Don't overheat the starter motor. Just be patient. Eventually it will run continuously (but only slowly) then it will come alive. Set the throttle to 1/2 and keep working it. May need to have a jump battery nearby. My F-935 does the same thing if I don't watch the fuel gauge. If it has a water separator, you need to bleed that, too.
Where are you in Brighton ? I'm at Old23 and Hyne Rd. If you still need help, give me a chirp back.
Good afternoon yeah I'm not in Brighton at the moment I'm down in Lucca in Italy
Anyway bled the fuel with the hand unit no air in the system all the way up to injector pump
When turning the ignition on the relay clicks and the valve operates
It did start briefly for about two seconds but after that no luck turned it over for 10 minutes until the battery went it is kind of running but it will not stay running without the starter motor turning
I've cracked of the injectors fuel is coming out of those
Lots of black smoke coming out of the exhaust and engine is hot because it is firing in some fashion but as I say not without the starter motor
I was on a very steep virtually on its side incline when it stopped running is there a tip valve on one of these
which may be tripped or something
Or is it just air in the fuel pump getting bored with it now
   / Bobcat 322 will not start after it was tipped over #5
I'm not a big fan of starting fluid, but do you have any? I assume you checked the air filter?
No not got any starter fluid I tried the WD-40 trick Took the pipe off the inlet manifold made no difference really
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
FRONTIER WR3210 LOT IDENTIFIER 108 (A53084)
FRONTIER WR3210...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
