bobcat 2025 filters
   / bobcat 2025 filters #1
MIkeWard
Long Island, NY
Bobcat 2025
2025 tractor time for oil change
I used a bobcat filter but found this info on tractor by net(can't find who posted it now.
Not all my research but might be useful in a pinch
Engine Oil Filter: Bobcat 7384298, Daedong E6201-32443, Purolator One PL10193 (extended life synthetic) , Wix 51381, Donaldson P550935, FRAM EG PH3985 long / PH3950 short, Luber-finer PH2856A
Hydraulic Filter: Bobcat 6695918, DaeDong T4260-38125, Donaldson P551779, Baldwin TST8488, WIX Filters - 57098 Heavy Duty Spin-On Hydraulic Filter
HST Filter: Bobcat 7375650, DaeDong T5855-46531, Donaldson P551348, Baldwin BT305 ,WIX Filters 51621
Air Filter: Donaldson part number label on the filter housing
Wix outer air filter - 46489
Wix inner air filter - 46490
Fuel Filter: Bobcat 7374363, WIX WF8059
Engine Oil is CK4 (suspercedes CK3 - for diesel)
Hydraulic / HST oil is GL4 and cross-references to Mobile 424 (specialized additives 10w30 for hydraulic)
Manual allows engine Oil based on temperature range: 10w30, 15w40, or 5w40 full synthetic (hint: Mobil 1 Delvac ESP full synthetic ,Mobilfluid 424}
   / bobcat 2025 filters #2
Hi Mike,
Amazing! Your results match those found in this post:
Yes that was it! Thanks FOP for the original info.
I found more info to add to it.
I needed the inner air filter.Went to check and clean air filters and guess what...
When dealers did last service they didn't have inner air filter (backordered even now) so they just left space empty. This was last year. Should have told me and left the old one in.
Found these on amazon
2023 Ford Expedition SUV (A59231)
2023 Ford...
Eagle Weathervane (A55853)
Eagle Weathervane...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
