Bob Cat vs Tractor quick disconnects
/ Bob Cat vs Tractor quick disconnects #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
I have ordered a WR Long 4n1 bucket..........do I use bobcat quick disconnects or regular tractor quick disconnects? If I go with regular tractor quick disconnects how hard would it be to make up an adapter to go from tractor to bobcat disconnects if I wanted to rent less say a hydraulic auger?
/ Bob Cat vs Tractor quick disconnects #2
Unless you have other implements that use flat face bobcat style couplers, I would recommend the regular "pioneer" style couplers. Tractor style couplers will be much cheaper and work just fine. If you plan to rent equipment which frequently use flat faced couplers, then I would go ahead and just put them on the tractor side. The flat faced come in styles including pipe thread and o ring. Sizes can vary from 3/4", 5/8" and 1/2". You may need to get adapters to fit to the tractor side depending on the size and thread type. Most flat faced couplers will run $50-60 each. Tractor couplers in the $10-14 range.
I also made a set of adapters with flat faced couplers on one end, a short adapter, and then tractor style on the other. (Use these mostly on the rear hydraulics). The adapters are easy to make. I used flat faced couplers with 1/2" pipe thread, mated to male/male 1/2" adapter, and then 1/2" pipe thread tractor style couplers. The flat faced couplers need to be one male and one female so it can match rented equipment. The tractor side will depend on the couplers on the tractor (male/female or male/male).
The biggest advantage to flat faced couplers is much higher flow rates but this is not an issue on tractor hydraulics.
Riding Lawn Mowers (A64557)
Riding Lawn Mowers...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Deutz D3006 Tractor (A62613)
Deutz D3006...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
90in. Work Bench (A65640)
90in. Work Bench...
200-gallon Poly Pickup Tank (A66408)
200-gallon Poly...
