bob cat 753 issue with forward right steering only?
/ bob cat 753 issue with forward right steering only? #1
TA INC
bobcat 753, john deer 1050
I have a 1994 Bobcat 753, when i bought the machine i tested it and seemed to be fine. ( yes I have driven them prior ).
second job i used it on I could tell I had to push the right joy stick more than the left to go forward. NO ISSUE GOING IN REVERSE. This gradually started to get worse as the day went.
It is almost barley moving forward ( THE RIGHT JOY STICK ). But the left works fine, and reverse on the RIGHT works fine.
Here is what we did so far. Rebuilt the drive motor seals, both sides, adjusted the steering linkages both sides about 20 times. ON the ground, and Raised off the ground on blocks.
STILL HAVE NO OR VERY LITTLE POWER TO THE RIGHT FORWARD????????????
Anyone have any clue what i can try next it would be greatly appreciated. Thank you in advance.
/ bob cat 753 issue with forward right steering only? #2
Sounds like the steering valve if adjusting the linkage didn't make any difference.
/ bob cat 753 issue with forward right steering only? #3
can you switch the motors to other sides and see if the left stops, any way to switch the motor lines and see if the direction changes
East Texas Gooseneck Trailer (A65563)
East Texas...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
