Boat trailer brake trouble
   / Boat trailer brake trouble #1
dstig1
Super Member
W Wisc
Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Posting this to help a friend as I am not familiar with these systems. It is a Mastercraft boat and trailer combo. The trailer is a single axle with hydraulic disc brakes (surge type brakes) in the ~5k lb range. He went to bring it in for winterizing/storage and found the brakes were dragging badly causing the wheels to get hot. Didn't go too far before turning around. He lives a couple blocks from the lake he goes to, so it never moves far except start and end of season. Brakes are definitely dragging based on some investigation he did. He took apart the surge mechanism in the tongue, and appears to be operating correctly. The only real suggestion I had was perhaps the flex lines to the calipers are swelled and restricting flow. Seen that on several cars when they got older. Other than that I do not know what to look for on this type system as I have not seen any of these before. Looking for advice or likely trouble spots to check out.
Thanks for any help!
Dave
   / Boat trailer brake trouble #2
Flex lines and reverse solenoid are always my starting pleace. 9 times out of 10 it's usually the flex lines.
If you are not familiar with a reverse solenoid it's a small electric solenoid placed behind the master cylinder that takes a signal (12v when tow vehicle is placed in reverse) and closes off the system preventing application of the brakes.
We are assuming here the cylinders or calipers are not frozen.
Is it a drum or disc system?
Chris
It is disc. Not sure if it has a reverse solenoid or not. Will forward this on to him.
Thanks!
Dave
   / Boat trailer brake trouble #4
It is disc. Not sure if it has a reverse solenoid or not. Will forward this on to him. Thanks! Dave
If it has disc it 99.9% has a reverse solenoid.
Chris
Thanks again, Chris
INOP/NON-RUNNING 2007 Peterbilt 378 Flatbed Mud Mixer Truck, VIN # 1XPFDT9X37D666626 (A51572)
INOP/NON-RUNNING...
New Long Forks (A53002)
New Long Forks...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
