Board and Batten Siding Question
   / Board and Batten Siding Question #1
HoustonBrama
Adams TN
New Holland TT60
I'm sure this is a stupid question, but I need to know the answer regardless.
Okay, I'm hanging green (from the mill) 1x8 siding. Is there a drying time or a time period I need to wait to hang the battens? If so, how long? Do I nail the battens directly through the boards and into the girts or try and nail through just the battens into the girts?
   / Board and Batten Siding Question #2
If you nail the battens on with a single row of nails, through the crack between the boards into the girts, you can put them on while everything is green. Do NOT nail through the boards themselves, or they will crack at the nails when they dry and shrink...
   / Board and Batten Siding Question #3
See if you can find a copy of "Installing Board-and-Batten Siding" in Fine Homebuilding, July, 1992. The batten should go on as soon as possible after the boards are up so they don't cup as they dry out. The battens don't just cover up the joint. They also are to hold the edges of the boards flat. You may need to predrill your battens to avoid splitting.
Another tip is to lightly bevel the bottom edge of the boards and battens to form a drip edge.
Thanks for the great info!
1997 STOUGHTON TRAILER DRYVAN (A53843)
1997 STOUGHTON...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
20" Sea Container (A47384)
20" Sea Container...
PALLET OF MISC. TRUCK PARTS (A53843)
PALLET OF MISC...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
