Bluetooth ear muffs
   / Bluetooth ear muffs #1
nyone
Veteran Member
Ford 851
About 4yrs ago I got a set of 3M bluetooth ear muffs. Love them but they slowly got quieter and quieter over the years, it's a known issue with this brand. Now the foam around the ears is falling apart.
Any one have any thst will last? Dont need AM/FM.
   / Bluetooth ear muffs #2
Bose. They were pricey, I forget the price but they have lasted 10 yrs so far and now they hang on the tractor in the barn. Original battery holds a long charge and the headset announces the percentage of charge when turned on which is helpful. Sound quality is awesome. I'm told they sound great on the phone too.
They are my go to mowing wear. Listening to music while mowing is my main use.
   / Bluetooth ear muffs #3
X2 on Bose. I have them for mowing. Very nice.
I have the Stihl Blue Tooth logging helmet for sawing. Works/protects very well.
   / Bluetooth ear muffs #4
I bought a pair maybe a decade ago. Died about the month the warranty ran out. Bought another pair, same thing.
Now I just buy good muffs and cram BT earbuds (~$15 and up) into the lining.
   / Bluetooth ear muffs #5
I do the same.
I use these Bluetooth earbuds from Bose and cover them with a pair of standard ear muff style hearing protectors.
and
QuietComfort Earbuds | Bose
When not listening to music, the noise cancelling feature can be used to eliminate noise that gets past the ear muff protectors.
The foam padding always seems to wear out on these muffs after awhile. This way you can replace them without having to replace the more expensive Bluetooth muffs.
   / Bluetooth ear muffs #6
I use the 3m Bluetooth headsets. When the padding wears out I replace with silicone pads, that are readily available.
   / Bluetooth ear muffs #7
Is there any model, reasonably priced, with a boom mike to allow conversations even with the earmuffs on?
   / Bluetooth ear muffs #8
Well, I'm a cheapskate and use the Q20i Soundcore headphones. They're an Anker brand. They work so well I bought another pair for use in the house when watching movies. The noise canceling option works great. I use it when Z-mowing and tractoring. And the rechargeable battery lasts a long time. They have multiple price levels so you can be as snooty as you can afford but still not break the budget.
   / Bluetooth ear muffs #9
Isotune, Link or Link Aware. OSHA compliant attenuator muffs, with Bluetooth added. I have two pair, the "Link Aware" which are mounted on my hardhat/saw helmet, and the other the Link2 with a headband I wear on the tractor and in the shop. Thinking of buying a third pair to mount on my Trend Air Helmet.
   / Bluetooth ear muffs #10
I have the 3M work tunes Bluetooth headphones. They have been working well and I haven’t experienced the issue that the OP is having.
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2013 Ford F-350 4WD Pickup Truck (A50860)
2013 Ford F-350...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2021 Ford F-150...
2008 Ford F-250 4x4 Reading Service Truck with Liftgate (A48081)
2008 Ford F-250...
