Blue Smoke on Startup
/ Blue Smoke on Startup #1
N1ST
Enfield, CT
Kubota B7800
Folks,
I have 15 hours on by B7800. I've noticed that when I start it after sitting for a few days to a week, I get a puff of blueish smoke and a knock or two. Today I started it after not running it for more than a week and I got blue smoke for about 5 seconds with loud running for the 5 seconds. I do use some of the white bottle Power Service and I let it idle for 5 minutes or so before I turn it off.
Is this blueish smoke anything to be concerned about? Thanks.
/ Blue Smoke on Startup #2
Not at all, it happens to all diesel's especially when the temps drop a bit.
/ Blue Smoke on Startup #3
Relax, everything sounds fine.
The Kubota engine you have is next to bullet proof.
The engine might even puff a small amount of smoke if you quickly power up or put it under a sudden heavy load.ie engage pto equipment or lift a heavy load.
I don't think you need to let it idle for 5 min before shutting down. If you where only doing light/medium work 1 min If under heavy load ie rototiller work or pulling a plow 2-3 min. will work.
Enjoy/work it....thats what it was made for!
Nice tractor and good luck
Frank
/ Blue Smoke on Startup #4
Is the smoke more light grey to white? That is normal if you don't cycle the glowplugs long enough. 5-10 seconds on the glowplugs should yield a good start with charcoal grey smoke, then let it idle for another 20-30 seconds before throttling up. Of course, winter temps require longer glow plug warm-up.
I've found with mine, if I throttle up only slightly when still cold, it coughs and chugs and spits out light grey smoke, but if I throttle it up a bit higher, the added heat clears it up pretty quick and gets it running smooth - that's if I don't give it enough idle warm up.
But it's always good to give a diesel a minute or two to warm up before getting to work.
/ Blue Smoke on Startup #5
Folks,
Iisn't the B7800 equipped with a preheater too? Anyway seriously consider a salamander or use one if you own one-the kerosene kind to preheat the tractor as it will help tremedously no matter the weather. Great for scaring rodents too.:eek::cool:
He keep me in mind as I would like to know what you think about the B7800 as I am looking to upgrade and replace my wheelhorse of 15 years-cant buy parts anymore or a new seat etc.
Thanks guys. You put me at ease. I've worked the tractor good from 4 hours. I have pto work to do, so I can't baby it. But I haven't abused it and I haven't run more than PTO speed which is that the manual says.
Yes the smoke is on the grey to white side. I glowed it for 3 secs and the temp was about 60f, so maybe that was part of it. And yes, I do notice a little puff of smoke when I thottle up quickly from idle to 1600.
Thanks again.
/ Blue Smoke on Startup #7
You remind me of a new parent bringing that first baby home from the hospital.
I know.... I did it with the kid AND THE TRACTOR.
Have fun!
/ Blue Smoke on Startup #8
nothing to be worred about its a diesel... they do that when they havent run in a bit.
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
17501-FL (A56857)
17501-FL (A56857)
2025 Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
2017 Hino 155 16ft. Box Truck (A59230)
2017 Hino 155...
