KWentling
- Joined
- Jun 22, 2002
- Messages
- 1,193
- Location
- Rozet, Wyoming
- Tractor
- Kubota BX22, Kubota ZD21, Kubota M7060
Wondering anyones opinion or experience with this. I have an old ('67) Case 830 with a Koyker loader (probably a little newer than the tractor, but not by much as it has rawhide piston seals) I handle big square hay bales with. The tractor sets outside for two or three weeks between uses. This past summer one of the bucket cylinders blew the seal in the head, I assume from pressure build up from setting in the sun. Didn't see or hear it happen but you could see there was hydraulic oil sprayed out. I replaced that seal and now the other cylinder did the same thing. I replaced that seal today. I've never heard of this before and I've been around equipment for 40 years. Is this just old age (of the seals, not me) or is there some other cause I should be looking for? I could tie the valve handle back to relieve the pressure but shouldn't need to. Any thoughts?
