Blown hydraulic pump on ford 3400
   / Blown hydraulic pump on ford 3400 #1
preddster
I have a ford 3400 that the hydraulic pump cracked on the bottom back when it was cold. So I thought It might have had some water in it and frozen and cracked. I had it welded and it has ran for a few weeks with a small drip. I fired it up the other day and pulled up the cylinders on the backhoe and it blew the pump again with the old crack reappearing. Now that I think about it the first time it happened I believe I was pulling up the cylinders on the backhoe part. So might my relief valve be failing? I had the idea of putting a relief valve either between the pump and the control box or on the box itself where there is a cap you can take off and hook up a gauge to check pressure. I don't know much about hydraulics and am just trying to learn. I have the service book for the backhoe. I just wanted to get up and running again and wondered if the inline relief valve would protect my pump if the other relief valve failed.
   / Blown hydraulic pump on ford 3400 #2
First, get a hyd gage and have it handy for test and trouble shooting.
Which relief are you talking about. If it has a FEL, there should be one on the FEL valve. There should be a relief on the BH. However if you want to protect the pump independent of the valves, you can install this before any valve.
https://www.surpluscenter.com/item.asp?item=9-6135-50-H&catname=hydraulic
Strange you should post that relief valve from that company. That is the very one from that retailer I was looking at.
   / Blown hydraulic pump on ford 3400 #4
shopping for answers eh? didn't like the first ones you got??? you've already been told about this issue from many others.
the crack had a poor 'fixing' cance and a relief likely isn't your issue now.. it's a new pump issue.
soundguy
   / Blown hydraulic pump on ford 3400 #5
Most cracked pumps fail from a dead head situation, and the valve relief might not help at all.
LMC LOT IDENTIFIER 128 (A53084)
LMC LOT IDENTIFIER...
JOHN DEERE 1700 LOT IDENTIFIER 17 (A53084)
JOHN DEERE 1700...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53472)
UNVERFERTH 330 -...
1556 (A51247)
1556 (A51247)
LOT IDENTIFIER 235 (A53084)
LOT IDENTIFIER 235...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51246)
MAH QUICK ATTACH...
