Blown head gasket? Can I use it?
   / Blown head gasket? Can I use it? #21
Gittyup, I feel for you: my NX had issues that were quite troubling; fortunately the dealer and Kioti resolved them (as they should with a brand new machine); but, I was really feeling shaky about my purchase. Vince mentioned the fuel bowl, that it's been upgraded. Were the other issues dealt with with upgraded parts?
I have an early Maytag front-load clothes washer. I had all sorts of problems with it. Someone came out to make the first repair. I then did the next one. Both covered under warranty. Both repairs were with updated parts. That was MANY years ago (I replaced the front drum seal- it was moldy; Maytag, long after the fact, said I had to use bleach to keep that from happening- I pointed out that they didn't mention that in their manual; I have since just allowed the door to stay open a bit when not in use- many years now and no issue). No failure of the two replacement parts. While not a tractor, it's an example of a manufacturer (mostly) recognizing and correcting their failures. I could have bailed early, but would I have got another manufacturer's product that still had bugs to work out?
A good dealer should go to bat for you if there's a good case. At a minimum I'd look to get to the bottom of why the failure. If I thought that it was a fluke, or that there's a better head gasket available, (and if there wasn't any factory or dealer support) I'd just do the job myself (save some money; and then I'd decide whether to keep or sell).
My B7800 really pissed me off a couple years back. I was banging it around pretty good, needing to get stuff done NOW, and the stupid fuel cap kept loosening up and or popping off, spilling fuel all over (and on me- back in the seat)! Went in to the dealer's and found that Kubota had updated the fuel cap. You'd think that anyone with the old style should get the new one for free, nope. Talk about stupid! (come on, Kubota, couldn't make a fuel cap that would hold up?)
   / Blown head gasket? Can I use it? #22
I just online priced a JD 2038R. Real nice tractor, with the typical JD advancements. But, ouch! It's expensive. Don't know what I'm going to do when I get my tractor back. I'd like to sell it. But, notwithstanding the expensive repairs every few hundred hours, it is paid for. What's next? Front axle? Clutch? PTO? I'm afraid to wait to find out.
If you don't have any confidence in it then sell it, they hold value real well. tough choice on what to replace it with. CJ
Kioti did step up on the injector and loader issues. Both were under warranty. But they both still cost me money and considerable down time. The problem with the head gasket is that it's a known recurring issue. One TBNer replaced his 3 times in about 1200 hours from what I remember, and the engine seized the 3rd time. I suspect that another head gasket failure will be in my future if I keep the tractor. Reliability just isn't there due to design, and the head gasket has inherent issues that aren't fixable. I'm doubtful Kioti will do anything to help on an 11 year old tractor just shy of 700 hours.
I bought the Kioti because it had the best digger specs in its class for far less money than the closest competitors. What good is saving money up front if it's going to keep breaking down and costing me time and money over the long haul. I want to work my tractor not work on it. I expect to get at least 1200 hours or more before any major repairs. Anything less would be defective in design, materials, or workmanship.
   / Blown head gasket? Can I use it? #24
Head gaskets seem to be somewhat problematic. We have had no repeat failures when new head bolts were installed along with the new gasket.
   / Blown head gasket? Can I use it? #25
In college I had an old Ford station wagon, I think it was about a 1962 with a 428 V8. I paid about $100 for it about 10 years old. It had a blown head gasket and the radiator gurgled, but you could run it with the fluid down a inch or so, the exhaust gas just vented through the radiator cap. Ran it that way for 2 years and as many miles as my student budget could afford in the great gas guzzler. Sold it to another student for the same $100 and I know he got at least another year out of it.
So it is possible, probably not a great idea, but possible.
Got an estimate for the repair. Close to $1500. Mechanic said one cylinder was scored and would require machining.
   / Blown head gasket? Can I use it? #27
Ouch on that repair. A scored cylinder is usually caused by antifreeze getting into the cylinder and washing down the cylinder wall. I blew a head gasket on one of my boats a few years back and had it hydro-lock. The cylinder was fine but the connecting rod sure got bent.
Update. They finally completed the repair on my tractor after 4 weeks plus one day. Total is $1416. I haven't picked it up yet nor seen an itemized list of what was done/replaced. I do know they sent the head out to get it machined.
   / Blown head gasket? Can I use it? #29
I'd be curious, that is actually pretty cheap if they pulled the block to have it bored. Unless they honed it and the damage was not that bad. CJ
   / Blown head gasket? Can I use it? #30
I mean its not ideal, and early in the tractors life but 1416, while cost a good chunk of money, if the tractor will go another 11 years or longer with new parts that alot cheaper than buying another tractor. I mean 1416 for the work they did is not to bad at all. I would feel a little PO'd but you can at least say the motor was gone through and fixed. I mean for a car thats a set of brakes and a tire set which will always need to be done at some point. It is cheaper than I would have thought.
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
(2) 5' TRAILER RAMPS (A57192)
(2) 5' TRAILER...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2017 FREIGHTLINER...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
Wooden Rocking Chair (A55853)
Wooden Rocking...
