Blown F1 fuse, NOT the CSA.
   / Blown F1 fuse, NOT the CSA. #1
jsasser
JD 5625, JD 4320, Kubota M9540D
On a 5625, while running, I came to a stop, put in neutral, brought engine to high rev to engage PTO, pulled PTO lever 1/2 way, and before the PTO got to max rpm, the tractor shuts down.
I instantly knew which fuse to check, the F1 key switch fuse. I’ve experienced this fuse blowing in the past. I’ve already replaced the CSA sensor, in fact when I discovered the fuse had blown, I unplugged the CSA and replaced the fuse just for it to blow again.
So, my question is, if it’s not the CSA, then what else could it be?
I’ll note, 10 minutes before this happened, tractor was running fine while bushhogging for about 15 mins.
Almost daily use tractor.
   / Blown F1 fuse, NOT the CSA. #2
Welcome to TBN
Tell us what "CSA" stands for in your post.
Related to this thread?
Welcome to TBN
Cold Start Advance sensor = CSA. Thanks, I should’ve clarified that.
2006 KENWORTH T300 BED TRUCK (A45046)
2006 KENWORTH T300...
1995 TOYOTA LAND CRUISER SUV (A43004)
1995 TOYOTA LAND...
2015 FORD F-350 (A45333)
2015 FORD F-350...
2011 LONE STAR UTILITY TRAILER (A45333)
2011 LONE STAR...
2018 FORD F-550 SERVICE TRUCK (A45046)
2018 FORD F-550...
2020 John Deere 50G Excavator (A42203)
2020 John Deere...
