blowing smoke
   / blowing smoke #1
bubbu55
North Creek N.Y.
Kioti CK35 HST
My 08 ck35 is starting a little hard and blowing out more smoke than usual at start-up. It's just at start-up and then everything is fine, while I'm working with it I shut it off do do some work and it starts up fine with no smoke, just like normal. Symptoms must point to something and I'm sure I'm at the right place to get answers. Thanks guys.
   / blowing smoke #2
Glow plugs not working as well as they use to. Or maybe one has gone bad.
   / blowing smoke #3
My best guess is that the glow plugs are bad. Probably just one since it still starts somewhat normal.
You can test them with a simple multi-meter. There are loads of videos and guides out there on how to check the glow plugs.
   / blowing smoke #5
^^^ Important troubleshooting tip.
   / blowing smoke #7
Check for power getting to the glow plugs
   / blowing smoke #8
As Vince says, check the glow plugs. After that I'd be thinking injectors: not seating fully, dribbling fuel (residual pressure after shutting down and fuel pools up a bit); it's less an issue when starting warm because the excess fuel will ignite pretty fast.
   / blowing smoke #9
SO many say the glow plugs but the glow plugs do not work when the engine is warm. If the OP only shuts the tractor down for a short period of time, the glow plugs will not work.
   / blowing smoke #10
Yes and this is what the OP said.
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A51242)
2006 CATERPILLAR...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
2025 Quality Steel Trailer (A50515)
2025 Quality Steel...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
