Block Wall
/ Block Wall #1
MADRanch
Parker County, TX
Kubota M5040
I have 1/2 dozen 4' cube block 'goat houses' I would like to take down. I would like to salvage the cement block, any idea on how to cut apart the mortar holding the block together?
/ Block Wall #2
If they are done with standard mortar once you get the first couple out the rest should come off pretty easy with a few gentle taps of a hammer on a block of wood. Tap each block at the corner where the web is, less chance of breakage. You should expect to break the odd one. The mortar is quite strong under compression but not so much otherwise.
If the voids have been poured with concrete then you won't be able to save the blocks.
/ Block Wall #3
I used a steel chisel and a shop hammer.I just tapped it down the mortar line and then gave a good tap on top.Most split down the mortar.
/ Block Wall #5
Just cleaned up about 200 blocks with an air chisel, took about 3 hours and a six pack.
/ Block Wall #8
Blocks can be difficult to clean especially if it was a good mortar mix and was protected from the elements with a decent roof.
Probably 4 or 6 inch block? If you could at least get them apart with out destroying them which also might be tough with such a small structure, as it's all corners. If you don't need them right away you could leave them out in the elements for a couple of years then the mortar would come off easier with just a masons hammer.
If you had to cut and grind them all with diamond tools then you'd be better off just buying new at a couple bucks each, IMO.
/ Block Wall
Thanks guys, I'm going to tare into one of them this weekend with a hammer and chisel and see what happens.
/ Block Wall #11
HEY BUDDY I USED A HAMMER DRILL WITH A HOME MADE CHISEL END WORKED GREAT FOR TAKE DOWN AND FOR CLEANING UP THE MORTAR GOOD LUCK
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
2020 Peterbilt 337 S/A Dump Truck (A64556)
2020 Peterbilt 337...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
UNUSED 2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
TAYLOR LASTOVER HARVESTER (A64278)
TAYLOR LASTOVER...
