• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Block heaters
   / Block heaters #1
white4768
summit tx25
Any time the temp is below 50 deg tractor will not start I have to put a heater on it. glow plugs get turned on three four times does not help. thinking of adding a block heater.
   / Block heaters #2
Something sounds off. Just started my D702 Kubota @ 10 F, cycled the Glow Plugs twice, fired, twice again and started. (at about 1/2 throttle)
Still has Summer Fuel (with Conditioner)
Are you sure your Glow Plugs are working?
   / Block heaters #3
Happy New Year, Summit gang.
Chiming in to say I’m in a cold winter climate and get my TX25 started in (well) below freezing weather using the following:
Hot Shots Winter Anti-Gel diesel treatment
Battery on a charger/trickle all winter
KAT’s 200 watt Magnetic Block Heater
I use the block heater on the oil pan for an hour or two, but I believe it has an auto-off feature.
Although I think about it…I have not used a temperature gun to determine whether or not the ‘heater’s actually making a difference. That said, the product gets great reviews.
   / Block heaters #4
You need to verify glow plug circuit is operational. I had to replace my glow plugs when it became harder and harder to start in 50° weather. Now with new plugs, she starts first time in 5°F weather.
   / Block heaters #5
Agree with all here and my $0.02 is that a lower radiator hose heater might be an easier option for you also. Mine works great for years!
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
2005 MERCEDES CLK 500 COUPE (A60430)
2005 MERCEDES CLK...
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
Ad bottom of page
