Block heater
   / Block heater #2
Internal or external?
   / Block heater #3
My preference is freeze plug type heaters.
   / Block heater #4
Years ago, I had a 68 Plymouth which had an external propane engine heater. As I recall it was built by Phillips Industries in Minneapolis.
There was a small propane tank in the trunk, a heating tank inserted into the lower radiator hose, which was fired by a glow plug. No extension cords needed, it used the 12 volts from the battery to fire off using a glow plug, then would run with no electric usage. The on off controls were also under the hood.
   / Block heater #5
Most efficient is frost plug block heater since all the heat goes directly into the block. Also usually lowest wattage so uses the least electricity
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
12.7 LITER DETROIT GENERATOR SKID (A50854)
12.7 LITER DETROIT...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
