Block Heater??
   / Block Heater?? #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I have newer vehicles- both tractor and trucks. I've read a lot of posts recently about Engine Block heaters (''tis the season!!) I've visited the websites for a few heaters and they make the claim of reduced emissions (less time it runs rich) and that your heater will blow warm air sooner. But none of the sites list easier starting as a benefit.
I realize in extreme cold like Alaska and parts of Canada it's a different story with fuel line heaters, battery heaters etc. That's not what I'm asking about.
From what I understand the glow plug or grid heater is heating the combustion chamber. The newer multi-viscosity and especially synthetic oils seem to flow better when cold. And the metallurgy is better as well.
So what is the reason folks in the lower 48 are adding block heaters to modern tractors? I tried to buy one from the dealer and he said I didn't need it. I could see an oil heater if things were below zero and you wanted better oil flow immediately, but not the engine block heater. Has someone had a modern tractor fail to start when cold? Then suddenly start with a block heater added? Or maybe someone has a link with good data on the subject?
Been around engines in mild climates for some time but north Idaho is new to me.
   / Block Heater?? #2
What's been your experience with the weather the Northern Rockies has been having recently? Unless you keep your machine in a heated shed, you've probably had difficulty starting a diesel without a block heater for a starting aid..
Here's the deal with diesel engines. First the compression ratios are very high (17:1) which requires more power than the same displacement spark ignition engine. The fuel/air charge requires the high temperatures to begin the combustion reaction and cold cylinder walls and head have a deactivating effect on chemical reactions that need to take place. Oil viscosity is high at lower temperatures so power required for cranking the engine is increased even with synthetic oils( that not to say that synthetic oils don't reduce power required relative to dino oils but the power required is increased by decreased temperatures). Finally battery output is decreased significantly by low temperatures.
A block heater warms the coolant which warms the cylinder walls and the head and the oil on those walls and the head and that reduces the power required to crank the engine. The fuel/air charge is somewhat warmed and the temperature rise of the charge is higher resulting in better combustion starting conditions. I have a 2007 New Holland TD95D that I feed with. This is a "modern diesel" engine (Tier II). I experience very similar ambient temperatures to Northern Idaho. I have difficulty starting at 10F without a block heater with a good battery, winter fuel, and an engine with 454 hours on it. ( just replaced the block heater on Saturday December 10th because the old block heater failed!) With the block heater plugged in for two hours at 10F ambient temperature the engine starts on the first turn.
Don't let a dealer talk you out of using a block heater in Northern Idaho. for a diesel powered tractor. All my diesels have them and they start on the first roll after preheating with a block heater. I can only share my experience with you but I'm sure there is hard engineering data data available for using block heaters as a starting aid. That's why outfits like Phillips Temro make so many different versions to fit a wide variety of diesels. And by the way they make for easy starting on spark ignition engine too.
   / Block Heater?? #3
I'll second Jerry, we got to -30F two winters ago and my 2011 deere would not have started without the block heater!!! We typically do not see temps that cold, but below 0 is not unusual. I do run full synthetic oil in my tractors as well.
   / Block Heater??
Thanks for the info. So far so good starting here but it's only been in the teens. I've had the Duramax at 2°f without issue as well.
EURIKA!!!! On the Phillips Temro site with regards to block heater temps. The GM heater doesn't kick on until the ambient air temp is 0°f or -18c. That's the type of info I have been looking for. According to GM somewhere around 0°f is when I should be thinking about the block heater.
Here is the link-
FAQs
Like I said in my post I understand the oil heater. That is easy enough to visualize and see- pour your motor oil of choice and see what temp it is pouring or flowing at an undesired rate. Below that- add heat!
Thank you again for the info!
   / Block Heater?? #5
I don't NEED a block heater, but even at 20 deg f there is a significant difference in starting with a block heater. At my first coolant change I'm going to install one on my current tractor.
   / Block Heater?? #6
Thanks for the info. So far so good starting here but it's only been in the teens. I've had the Duramax at 2ーf without issue as well.
EURIKA!!!! On the Phillips Temro site with regards to block heater temps. The GM heater doesn't kick on until the ambient air temp is 0ーf or -18c. That's the type of info I have been looking for. According to GM somewhere around 0ーf is when I should be thinking about the block heater.
Here is the link-
FAQs
I'm glad you found it useful.
   / Block Heater?? #7
My Kubota came with a block heater. I have not needed it yet but if we ever get another winter of -35 for a week it will be used. I have started my diesel engines have started in -10 but they are in a pole barn
   / Block Heater?? #8
First things first here - if its -20F or colder - its gonna take a mighty big wench to pull me outa the house. I did go out once at -20F and start the tractor - last time for that stupidity. Operating an open station tractor at those temps, putting your buns on a frozen vinyl seat - not for me. For whatever reason I've never liked block heaters. I've always used lower radiator hose tank heaters. I've always found that a vehicle will start easier if heated one way or another.
That being said - I have no heaters on any of my vehicles. All my vehicles are in separate stalls in my carport. They all have Deltron battery tenders and have always started fine. It just takes longer for them to come up to operating temps.
   / Block Heater?? #9
Diesel engines with common rail systems and electronic injectors start much better than old design mechanical injection pumps that simply dump fuel in at a predetermined rate.
Reason being the computer adds a very tiny shot of fuel on the compression stroke at cold ambient temps that starts the combustion process seamlessly. The difference in cold starting is night and day.
If your tractor has an old school injection pump then a block heater will help. Cold here and when the temps hit zero my machines won't start without a little help.
Regards, Fred
   / Block Heater?? #10
When the temps are below freezing the diesel gets plugged in. $0.18/kwh is a lot cheaper than a starter and the added heat makes them (a) start easier and (b) warm up faster. The gasser gets a couple of hours of block heater after the tractor is running for the same reasons.
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A50860)
2025 K0311 UNUSED...
2024 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2024 Chevrolet...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
19009 (A48082)
19009 (A48082)
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
