block heater
   / block heater #1
TZ25DA
New Holland TZ25DA
Hi I just installed a New Holland brand block heater in my 2007 TZ25DA. I torqued it to 25 in/lbs and it doesn't leak but I can easily rotate it 30 degrees from the recomended 6 o'clock position. Is this normal? Thanks, Steve.
   / block heater #2
Steve, I have had a block heater in my 1700 for 30 years with no leaks but it does not rotate. Wait for more opinions as I am not a mechanic but I think you need to tork it until it quits rotating. It may not leak now but I bet it starts leaking at an inoportune time when you are working the tractor in 10 deg weather moving snow or a 105 deg day when you are moving dirt. But like I said, before you do that, get more opinions.
   / block heater #3
If it's like the ones I have installed there is a toggle-type bolt that has two wings that contact the inside of the block casting. The center bolt then tightens to pull the o-ring against the block. No way that should turn in the machined hole in the block - seems likely to leak some time. The newer one I put in 3-4 years ago the wings were too weak to permit a tight seal, so I salvaged the wings from the old one. Kind of a flimsy design as I recall.
Jim
2006 Pierce Dash Fire Truck (A51692)
2006 Pierce Dash...
Roll Off Dumpster Body w/ Assorted Tires (A51692)
Roll Off Dumpster...
1996 STOUGHTON TRAILER DRYVAN (A53843)
1996 STOUGHTON...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2015 Dodge Dart Sedan (A51694)
2015 Dodge Dart...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
