block heater
   / block heater #1
TZ25DA
New Holland TZ25DA
Hi I just installed a New Holland brand block heater in my 2007 TZ25DA. I torqued it to 25 in/lbs and it doesn't leak but I can easily rotate it 30 degrees from the recomended 6 o'clock position. Is this normal? Thanks, Steve.
   / block heater #2
Steve, I have had a block heater in my 1700 for 30 years with no leaks but it does not rotate. Wait for more opinions as I am not a mechanic but I think you need to tork it until it quits rotating. It may not leak now but I bet it starts leaking at an inoportune time when you are working the tractor in 10 deg weather moving snow or a 105 deg day when you are moving dirt. But like I said, before you do that, get more opinions.
   / block heater #3
If it's like the ones I have installed there is a toggle-type bolt that has two wings that contact the inside of the block casting. The center bolt then tightens to pull the o-ring against the block. No way that should turn in the machined hole in the block - seems likely to leak some time. The newer one I put in 3-4 years ago the wings were too weak to permit a tight seal, so I salvaged the wings from the old one. Kind of a flimsy design as I recall.
Jim
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 KENWORTH T800 (INOPERABLE) (A53843)
2018 KENWORTH T800...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2015 DODGE RAM...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
