Block Heater
/ Block Heater #1
Becharpa
Bridgton, maine
Mahindra 2015HST
Has anyone installed a block heater in a Mahindra 2015HST? Are there details diagrams without having to buy a service manual?
/ Block Heater #2
A lower rad hose heater will fit every model of tractor. I just came in from plugging mine in at 10F so in 1 hour it will be warm.
Craig Clayton
/ Block Heater #3
I agree, A lower hose heater is available at most any auto parts store and can installed in less than an hour. I went that route also on my 2615HST.
/ Block Heater
I was also thinking of a magnetic heater that attaches to block on outside, they generate about 300 watts? Any thoughts?
/ Block Heater #5
I bought a magnetic heater at the time I bought my lower hose heater.
It had it stuck to the oil pan because there was not a spot on the block flat enough to stick it to. I tried to just unplug it and go but it would get knocked off moving snow. It was an inconvenience to get under the tractor to remove it every time I wanted to use it. The lower hose heater works great for me.
/ Block Heater #6
Craig Clayton
Count me as another fan of the lower radiator hose :thumbsup:, bought mine at tractor supply 6 yrs ago, plug mine in when I first get into the barn about two hours later she starts on the first try, last week -12 below gave it 3 hours.
P.S. for all you ny guys, the ny farm show starts feb.24-25-26 at the state fair grounds, huge amount of equipment dealers & vendors ,gets you thinking of spring
/ Block Heater #7
I was also thinking of a magnetic heater that attaches to block on outside, they generate about 300 watts? Any thoughts?/QUOTE]
Save your money. Leave it in the store. :thumbsup:
/ Block Heater #8
Egon- I have seen Kats magnetic heaters listed at 300 and 600 watts and am interested as you are but am wondering what wattage is recommended.
Oldstuff
/ Block Heater #9
Seems I didn't express myself as well as I could have. For some reason the magnetic heaters do not impress me. Some folks say they work well though.:)
/ Block Heater #10
Have you checked out the different manufactures of oil pan heaters like Wolverine instead of the inline tank water heaters.
A conventional tank heater does a great job heating the water in your engine. But does nothing to warm the oil. Cold oil takes time to start flowing when you start your vehicle. Until the oil flows, you are wearing out your engine. This heater keeps the oil warm and flowing no matter the outside temperature.
/ Block Heater #11
Magnetic block heaters heat the air but not the engine.
Been there , done that, 6 hours of heating and no joy.
Go frost plug or rad hose.
/ Block Heater #12
I tried the smaller magnetic heater 3"x4" 150 watts I attached it to oil pan. Problem is that it accumluated moisture due to fact that there is a gap between steel and plastic housing...Left heater on overnight went up to barn next morning smelled burnt plastic & heater had shorted out melted plastic. Lucky for me it melted and seperated the internal elec connection thus did not burn down barn. The plastic got so hot that it got stringy looked like a messed up smores! So I agree leave mag heater at store! I now use a sillicone 150 watt sticky back Kats heater $38 on the oil pan. Tie wrap cord or you'll break yours off while clearing brush. Sounds like lower hose heater is best bet. Burning down barn with tractor,backhoe attachment,automotive lift, 20+yrs tools and maybe work truck beside barn PRICELESS!!!::eek:
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2014 Link-Belt 350X4 Hydraulic Excavator (A61572)
2014 Link-Belt...
Tube Line Manure Spreader Nitro 275RS (A63688)
Tube Line Manure...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
Caterpillar 914G/IT14G Wheel Loader Parts and Service Manuals (A63117)
Caterpillar...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
