Block heater trips breaker
   / Block heater trips breaker #1
JMarchant
Littleton, MA
JD 301A
Hi - I have a John Deere 301A with a block heater. Sometimes it will heat the block without problems but most of the time it trips the breaker within 10 seconds or so. The heater has about a 6' cord and I'm using a heavy duty 8' extension cord. Do you think the cord is the problem? I was thinking about installing a new receptacle so I could plug the heater in directly - do you think that would help? Thanks
   / Block heater trips breaker #2
I shouldn稚 trip. The more powerful block heaters are 1500w which is about the same as a hairdryer. More than likely though, yours is 400w. Have you checked to see what else is on the circuit?
   / Block heater trips breaker #3
Breakers deteriorate over years. How old is your wiring?
Most home circuits are 15 amps, so a 1,500 watt load is near max with a NEW breaker. Start up surge requires more power than later run.
If you install a new, more convenient receptacle be sure to include a GFI so you do not electrocute yourself.
   / Block heater trips breaker #4
1500 Watts is 12.5amps on a 120v circuit, so that in and of itself won稚 likely trip it, but it doesn稚 leave a lot of room for anything else to run a 15amp circuit. But like I said, you probably have a 400w heater which is only 3.3 amps.
   / Block heater trips breaker #5
Try plugging in another high-wattage item, like a hair dryer, and see if it still trips. Try plugging in block heater to a different circuit, and see if the different circuit trips... isolate the issue using the process of elimination.
   / Block heater trips breaker #6
I would start by plugging it into another circuit. Preferably one with a gfi. If it pops the breaker then the circuit is overloaded. If it pops the gfi then there is a short in the heater and/or it痴 power cable.
   / Block heater trips breaker #7
You might able to check the resistance in the heater element. Higher reading probably tells you it not good. I would think it's going bad.
Thanks everyone,
The wiring is new and this is a dedicated circuit. I tried a new 20amp breaker - no luck. I tried installing a different receptacle - no luck. When I plug in a 1750 W heat gun, it works fine. When the block heater causes the trip it takes 10s or so to happen which seems strange (if a short I would think it would trip immediately). The heater is new last spring. Very strange!
   / Block heater trips breaker #9
Can you replace just the cord on the heater. Least that would rule that out.
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
