Block heater plug
/ Block heater plug #1
gregolma
Ford 3550
My Ford 3550 3 Cyl diesel has what looks to be a factory block heater, but the plug is missing. Any idea where I can buy one?
/ Block heater plug #2
That’s a very good question, hopefully someone has a helpful answer for you
/ Block heater plug #3
Looks like it has some raised manufacture info on the part that seals the plug to the block. I'd go after it with a brush and some fuel to see if any info appears.
/ Block heater plug #4
Looks like a typical "automotive block heater" plug to me.
Check KAT's
/ Block heater plug #5
Before buying a standard cord for that heater I would check the continuity of the element with an ohmmeter. There may be a good reason the cord is no longer present.
/ Block heater plug #7
Messick's. Doesn't look like the cord is available separate for that model.
/ Block heater plug #9
Do you have any auto re-cyclers around your area ? If so, you might be able to buy one cheap, after you remove it from the exact same block heater.
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2012 Chevrolet Colorado (A64194)
2012 Chevrolet...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
