block heater or dipstick heater ?
   / block heater or dipstick heater ? #1
weaver
Brooklyn CT.
little beaver/1430 pt
Well I live in new england and I going to use my 1430 ( duetz diesal) to move fire wood in winter . I have a dipstick heater and added winter fuel additive which sould help me on cold starts , does any one use anything else like block heaters?
   / block heater or dipstick heater ? #2
Re: block heater or dipstick heater ?
There is a glow plug system availilbe from Deutz. I think it is around $150. The lowest I've started mine this year is 33 degrees so we will see how it does at 25. Maybe it's time to install that new heater in my shop /forums/images/graemlins/shocked.gif
   / block heater or dipstick heater ? #3
So far I've been able to start my 1845 Deutz down to about zero degrees F with no heat, though it does crank quite a long time before it will fire strongly enough to sustain itself at such low temps. It's the best cold weather starting diesel I've come across. I have no source of power where the PT is parked and have been thinking of looking into an intake manifold heater Deutz offers. But somehow, once PT is running it just slips my mind - until next time... /forums/images/graemlins/tongue.gif
Sedgewood
   / block heater or dipstick heater ? #4
Wasn't someone talking about pointing a blow dryer down the air intake as well? Poor man's alternative. /forums/images/graemlins/wink.gif
   / block heater or dipstick heater ? #5
I use my 1430 a lot in Winter and like Sedgewood not much problem down to about zero. Also have to crank it with the starter longer untill it runs on it's own so a good battery is a must. Once started, it will run on one cylinder for a while and hydraulics real sluggish so let it warm up for a while before moving the tractor.
   / block heater or dipstick heater ? #6
For those cold winter mornings I use the following:
block heater for the oil tank
1.5 amp trickle charger
Lotsa luck /forums/images/graemlins/grin.gif
Never had a problem until it gets to -30 or so then I put the heavy duty jump starter on the battery for a boost.
PJ
   / block heater or dipstick heater ? #7
" Never had a problem until it gets to -30 or so then I put the heavy duty jump starter on the battery for a boost. "
At -30 I'm inside next to the heater. Thank goodness it don't snow when it's that cold.
2015 Haulotte 5533A (A53316)
2015 Haulotte...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
Schulte SBW800 Rock Windrower (A56435)
Schulte SBW800...
LandHonor PTO Skid Steer Attachment (A56857)
LandHonor PTO Skid...
