Block Heater on a JD990?
   / Block Heater on a JD990?
I was thinking the same thing ,hate the idea of wreslin' the tire off and on , with the wheel weights and all ........... Wondering if I can jack up that side and sneak it in without a gush of oil to worry about ...
Bill G.
   / Block Heater on a JD990? #32
Hi Zuiko
There should be plenty of room to do it with the tire on. I debated about that myself, but the JD mechanic recommended it, and it wasn't that big a deal for me. I don't have any wheel weights, although it is still a heavy assembly.
You may lose a little more fluid since you will have to put the plug in from a sideways angle, but it shouldn't be significant. I would pull the pin that holds the brake rod, and lower it out of the way.
As far as removing the wheel, just jack up the rear axle until the wheel slides off the hub, and then just roll it back and rest it against the ballast box, or other handy implement. Do the reverse to mount it back up. There is no need to lift the wheel and tire, just some gentle wrestling...
Please remember to put a jack stand under the axle at all times for safety !!! I had a friend crushed and killed when a jack slipped and he was working alone many years ago...Ouch
Good Luck and Have Fun,
John
   / Block Heater on a JD990? #33
Bill - I don't know when you last changed the tranny/hydraulic fluid and cleaned the screen/filter, but when I did mine a few months ago, the screen really needed to be cleaned.
BTW this tranny plug is MUCH easier to remove than the block plug heater, however you do need something large enough to catch all the oil. Just a thought...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
VIRNIG FORKS QUICK ATTACH PALLET FORKS W/ 48" (A52707)
VIRNIG FORKS QUICK...
2010 Ford F150 Single Cab Pickup Truck (A55973)
2010 Ford F150...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
