Block Heater on a BX 24
   / Block Heater on a BX 24 #1
whatever1
Earth
When it gets cold enough to use the block heater is there any harm to leaving it plugged in all the time or should I just plug it in just before I am going to start the tractor.
   / Block Heater on a BX 24 #2
You'll burn the element out quick if you leave it on, not to mention use a lot of electricity unnecessarily. 15 or 20 minutes on a cold day and my engine is toasty warm.
   / Block Heater on a BX 24 #3
A timer is a good thing to use with a block heater. I told my kid to unplug the block heater one day and he wandered off towards the shed. I looked 10 days later and the block heater was still plugged in running up my power bill 24/7.
darn fool kid just could not understand why I was upset.
   / Block Heater on a BX 24 #4
I use a heavy duty timer. Actually bought the 2 pack last year, 1 for truck and 1 for BX. Worked great. The pins kind of sucked, pretty much set and leave alone. Used 2 different times for the BX, before and after work.
Amazon.com: Intermatic TN311 15 Amp Heavy Duty Grounded Timer - 2-Pack: Home Improvement
I think the heater is 400 watts. I dont know about being toasty warm in 15 minutes but I'll time it for 1 hour before using it.
   / Block Heater on a BX 24 #5
I've got remote switches for both of my block heaters. The original GE switches quit working so I just bought 2 more from Home Hardware up here. They are made by woods.
I go to the kitchen window and click on the switch and the block heater comes on. I have a short string of LED christmas lights T'ed off of the line going to the heaters so I know for sure they are on. Lights are on....heaters are on.
Home Hardware - Remote Contol for Outdoor Lights and Decorations
   / Block Heater on a BX 24 #6
I should have noted that 15-20 minutes was what it takes for my block heater to get the engine warm, but it will depend on your tractor and the weather. I have a small 18 HP engine and live in KY where really cold temps are rare. If you have a larger tractor and live in a place with more extreme weather you'll, of course, need more time.
I'd recommend trial and error to find the correct amount of time needed.
Jeff
   / Block Heater on a BX 24 #7
If a storm is expected or I know that I will be using the tractor the next day i plug mine in the night before. The small amount of electricty used won't even be noticed on my electric bill and I know it is warm and ready to go.
   / Block Heater on a BX 24 #8
I plan to get a wemo outlet. I can then turn it on before I leave work, if needed.
Granted, requires some technical expertise, but mostly just needs wifi.
Boat (A51694)
Boat (A51694)
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
