block heater on a 4110 question
   / block heater on a 4110 question #1
chevelle67
I have a 4110 with a block heater and had it plugged in overnight, it worked good as the tractor started as if it was 75 degrees outside instead of 5 degrees. When I plugged it in this evening I was working in the garage and noticed it makes a hissing noise as if it was boiling water, I did not notice it last night but I was not out there long enough to hear it. I called the dealer but they closed. Anybody have any insight to this. Thank you.
   / block heater on a 4110 question #2
I've got a 4110 with a block heater and it does the same thing. I was mildly concerned when I heard it the other morning, but hearing your story makes me feel a little better. I don't know that it definitely should make the noise, but knowing its happening with another 4110 owner seems like a good sign. I'm curious to see what others have to say.
I haven't spent a lot of time analyzing my situation, but I think it only makes that noise when its been pluggen in for quite a while or if I plug it back in when the engine is still warm.
   / block heater on a 4110 question #3
That is perfectly normal, even my Ford deisel makes the same noise.
Here is a tip that I use on my truck to save electricity...I use a heavy duty (15amp)outdoor timer(Home Depot has them for about $15.00)and set it for 3 hours before I go to work. This works great for me and keeps the heater from being on an extra eight hours or so.
   / block heater on a 4110 question #4
That sound is completely normal, it is the coolant circulating throughout the block. I plug my 4110 in for an hour or so, and that's all it needs. I usually hear it within 5-10 seconds. Once, I did not hear the noise and went back to inspect it. I jiggled the plug (on the tractor), and the heater came to life. It seems that I had a bad connection. The next time I had the engine cover off, I removed the cord and cleaned the terminals on the heater. Haven't had the problem since.
   / block heater on a 4110 question #5
That's a good tip. I put my heater on an X10 controlled remote controlled outlet. I also put a lamp on the same outlet and put the lamp in the window of my shed. That way, I can turn the outlet on from the house with my remote control and the lamp in the window verifies that it's on and reminds me if I accidently left it on too long. It helps that the shed window is clearly visible from my bedroom bathroom.
I think the X10 remote control, the wireless receiver, and the lamp module cost me about $50.
   / block heater on a 4110 question #6
I don't hear the hissing on my 4600 - perhaps it's just the 4110... I like the idea of the timer though and I might just look into one. The heaters are a must, I believe (I have one for the hydraulics also), but not warming it up sufficiently with the heater and trying to turn it over too soon can definately take a battery down fast. /forums/images/graemlins/frown.gif
I just posted on this separately to see what others do - I know there are folks who don't have heaters who don't seem to have problems.... I'm curious as to what they are doing to address it. /forums/images/graemlins/confused.gif
-Bob
Thanks for the replies. I didnt think it was a big deal but wanted to make sure. The glow plugs work good but with the heater on there is no reason to use them. Thanks again
3pt 3 Row Cultivator (A53317)
3pt 3 Row...
2011 Forest River Crusader 320RLT 36ft. T/A 5th Wheel Travel Trailer (A55853)
2011 Forest River...
UNUSED FUTURE 19" MINI EXCAVATOR RAKE (A57193)
UNUSED FUTURE 19"...
2007 Ford E350 (A55973)
2007 Ford E350...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
