Block Heater Install
   / Block Heater Install #11
I also set it up on a belkin wemo wifi controlled outlet. Instead of having to walk out to my garage I can turn the block heater on from my phone a couple of hours before I need to use it. It works great!!
Well aren't we a princess!!!:laughing:
   / Block Heater Install #12
I have mine plugged into an RF controlled AC adapter which was $8 at Menards. The remote stays in the house.
   / Block Heater Install #13
Sure am. My garage is a few hundred feet away and down hill a ways. I don't feel like putting on my boots and trudging through the snow just to plug in a block heater and turn around. What can I say, I'm a little girl. :cowgirl:
   / Block Heater Install #14
Haveissues, Did you have to have internet at the outlet? That sounds like a great idea since my barn isn't next door for me!
It does need to have wireless internet. They make some that just use a radio signal and a little remote but I have no idea about the range.
The last needed tool arrived yesterday for the install of the block heater. Had to buy a 17mm hex socket wrench to remove the freeze plug and a 1 3/8 socket to install the heater. The draining of the coolant was easy now that Kubota has a "master" drain that does both the block and the radiator. All told, maybe 10 minutes work. Set it up with a remote switch from Amazon ($15) so I don't have to walk to my barn to turn it on. Works slick! thanks for the info guys!
   / Block Heater Install #16
Love those remote switches. I have two. One for the tractor and the other for the Heep.
   / Block Heater Install #17
I would just suggest that a couple of hours of block heater is probably a lot longer than needed, and may be "using" up the heater element. My B8200 is cold blooded- a bear to start without a block heater, but it only takes 20-30 minutes and it is good to go. I have a Canadian Kubota screw in heater.
I noticed that there was a bit of antifreeze leaking out of the block heater threads. Tightened it up a bit more (maybe 20 lbs) and it still weeped a bit. Bit the bullet. Drained the A/F, and removed the heater. Took off the Teflon tape I used (recommended by Kubota) and replaced with thread/pipe dope compound. Tightened it up again and have no leaks yet. Other than that, the heater works slick....motor fires up and runs smooth after an hour of using the heater! Got to be easier on the motor to start up warm versus zero degrees!
   / Block Heater Install #19
Yes Teflon tape sometimes does not work if it's put on ever so slightly wrong. There is a new to me product called brush on Teflon, looks like white pipe dope, works the nuts.
Devildog
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
