Block heater in B2650
   / Block heater in B2650 #2
Look for the attached wound up electrical cord, and follow it back, I would assume, to the side of the engine block.
   / Block heater in B2650 #3
I would say if you didn’t specifically ask for one when you bought it (assuming you bought it new)…there won’t be one. Unless the dealer puts one on as a perk…
At any rate, they are located on the left side of the engine (as you are sitting on it) threaded into the engine block between the oil filter and the starter….it’s a copper housing with a red plug coming out if it…
Here is mine:
   / Block heater in B2650 #4
Our B2650 heater on left hand side with cord hanging.
   / Block heater in B2650 #5
Same as mine, coiled up alongside the frame. It should be the only house style plug on your tractor.
I bought it used, so I don't know if the block heater option was installed. A cursory look didn't reveal a power cord, but I'll have to snoop a bit more deeply.
Thanks.
   / Block heater in B2650 #7
The cord coming out of the heater is really short, so it should be pretty close…
Here is the kit:
   / Block heater in B2650 #8
Question do these block heaters work?
2022 Toro Workman 07921 Electric Utility Cart (A55851)
2022 Toro Workman...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2019 Ford F-350 XL (A53317)
2019 Ford F-350 XL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57193)
KNOW BEFORE YOU...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
