Block Heater for my MT122 Yanmar
   / Block Heater for my MT122 Yanmar #1
joesco
I'm a big fan of block heaters as I believe it greatly extends the life of a diesel engine and helps greatly in starting in sub-freezing temperatures, even though my tractors is always in a unheated garage.
Is there a freeze plug on the Yanmar for a block heater. If so, does anyone have a part number for a Kats, which I've used in the past.
Thanks very much!
   / Block Heater for my MT122 Yanmar #2
You should be able to go to the Kats or Zero Start websites to research your application and proper location of install.
I found it much easier to just install a lower radiator hose heater.
   / Block Heater for my MT122 Yanmar #3
   / Block Heater for my MT122 Yanmar #4
I have tried different types of engine heaters, from the lower radiator hose heater, to a temporary magnetic heater. Honestly, the one that doesn't preform the best is the lower radiator hose heater. It does work, and is easy to install, but there are better options out there. Probably the best is the freeze plug heater. But even that will not warm the oil, so I found the magnetic style block heater works the best.
You can leave them on, but since they are magnetic, I just take it off after the tractor starts. When I shut it down, I simply stick it back on the oil pan. This heater warms the oil allowing the oil to flow better during cold startup. The coolant doesn't get too warmed, so my glow plugs actually do something. In my tractor, the ECU reads the coolant temp to determine how long the glow plugs should run. If the coolant is nice and warm, the glow plugs don't fire, and I attempt a cold start. Some have said to simply turn the key backwards, to override it, but that does not work in my tractor (maybe yours?)
In all, the main concerns for me while attempting to start the tractor in cold weather are: 1) To actually start. 2) Protect the engine and turbo. 3) shorten warm up times. By warming the oil, all three are accomplished.
   / Block Heater for my MT122 Yanmar #5
Magnetic block heater sounds like a great idea but I tried one many years ago and it didn’t seem to help much, just read a bunch of reviews on Amazon and they mostly were not very good.
Two of my tractors have block heaters that heat the antifreeze and they work pretty well but if it’s really cold below zero they need to be plugged in for more than1-2 hours, more like about 8 hours then it starts pretty easy.
Thanks for all the input folks. Over there years I've install four block heaters in my tractors and if I recall my Kill-A-Watt meter displayed 400-600 watts.
In some cases, after being on a timer for about three hours, I wouldn't even need my glow plugs to start them.
I still have an old 300 watt magnet heater, but never had much luck with them. Much appreciated all the input!
2005 Military Trailer (A53424)
2005 Military...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2014 John Deere 204K Wheel Loader (A53485)
2014 John Deere...
2021 BOBCAT S740 SKID STEER (A52707)
2021 BOBCAT S740...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2012 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2012 POLAR TANK...
