Oil & Fuel Block heater for B7100
   / Block heater for B7100 #1
carmichaelb
Alaska
Kubota B7100
I am looking for a block heater for a B7100. My local dealer said Kubota does not carry them any more. Does anyone know where I could find one?
   / Block heater for B7100 #3
My dealer put an inline heater in the lower rad hose. I wasn't happy at first but it works fine.
If you do go for the real core plug type block heater you may find that not all block locations have enough clearance in the cooling passages to accept the heating element.
Maybe someone can chime in on where their's is installed.
   / Block heater for B7100 #4
I put a lower radiator hose heater on my B7100. It works fine.
I have had the problem of a block heater not fitting when a parts house sold me the wrong one. That is why I was hoping someone could tell me the the lenth and angle of bend needed to fit. I can use the pump type but up here they seem to burn out fast. I will go that route if i do not hear anything eles. Thanks for the ideas.
i found the block heater. My dealer decided to look at other equipment that uses the same size engine and got a part number form there. I will post the part number once I proof it.
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
