Block heater b7500
/ Block heater b7500 #1
Anonymous Poster
Epic Contributor
How tough is it to install a block heater for a b7500? Is it just a bolt on or do hoses have to be cut?
/ Block heater b7500 #2
The correct block heater for that model goes into the block of the tractor.
Thanks for the information. How tough is it to put the heater into the block? Is it a 5 minute job or a whole day affair? I have no clue.
/ Block heater b7500 #4
Jared, I have seen some after market block heaters at auto supply stores that are magnetic and just stick to the oilpan. I dont know how well they would work on a tractor though? also have seen the tank type that go in line of radiator hose. The magnetic ones look like a simple alternative if you dont want a permanent install?
/ Block heater b7500 #5
I think most, if not all, block heaters are installed by removing a freeze plug in the block and replacing the plug with the block heater. I haven't done it myself, but I don't think it's too difficult. Large plugs are removed by drilling out the centre and removing with a slide hammer or similar tool. Small plugs can be removed by prying them out with a punch or chisel. Of course, care should be taken when prying or banging on any cast part such as an engine block. Castings break easily, and they are expensive to replace.
Other type heaters are probably easier to install, but block heaters are probably preferable. I think block heaters are better at keeping cylinder walls warm than other heater types. Warm cylinder walls help diesels to start in cold weather. Perhaps the 're-circulating' types installed in rad lines accomplish the same thing, but everybody around here uses block heaters on everything.
Magnetic oil pan heaters may keep the oil warm, but do little for engine block temperature. I use a 0W-30 engine oil, which is probably better at keeping oil thin in cold weather than an oil pan heater. I do use several magnetic heaters on the transmission case, even though my dealer says they don't actually do much. The dealer said that using a good winter hydraulic oil is better than heaters.
/ Block heater b7500 #6
i installed a block heater on my 7500 dt. It has a threaded plug that is lock tited in place. if i remember correctly it requires a 17mm allen wrench
/ Block heater b7500 #7
I installed a factory Kubota block heater in my 7500. It installs on the left side of the block and is threaded. I had to drain down the coolant then do the installation, it took about a half hour. not sure on the price, but my dealer charged me under $50.
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
Informational Lot - Shipping (A63688)
Informational Lot...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
