Block Foundation Help
/ Block Foundation Help #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hey everyone,
I have a block foundation that supports my back deck. It was fine when I
moved in 12 years ago, but it is crumbling in spots.
I what would cause this? How can this be fixed?
Thanks
Dave
/ Block Foundation Help #2
Bummer. I've never saw that before. But I'm not a block guy.
Hopefully the experts will chime in with cause and solution.
/ Block Foundation Help #3
Spalling. Same thing you see on sidewalks. Just age in some cases, but the blocks could have been bad from the start. Moisture encroaches and a chemical reaction starts. Only way I know to fix it is to break out any loose material and fill with new concrete. Then maybe coat with Drylock paint or a foundation coating.
What's on the other side of the block, do you know?
/ Block Foundation Help #4
X2 with Diggin It. Plus probably over the years the freeze thaw cycle from snow and rain has weakened the block where it chips off. I think Quickcrete sells a mortar patch mix in like a gallon pail. HD and Lowes sells it. Before patching put a coat of concrete adhesive ( comes in a plastic quart bottle ) on the repair area....it lets the patching mortar adhere better.
